Frank Acampora
- Joined
- Jan 19, 2007
- 12,004
Re: Solo hand loading boat question
BTW: Drill a small hole (about 1/8 to 3/16 inch) centered in the bottom of both crossmembers under the keel rollers. No matter what you do, water will get into the crossmembers and collect there. Eventually it rusts out the crossmember right under the rollers.
Yeah! I have that trailer model too with 12 inch tires. I removed both bogeys and replaced them with bunks. I drilled the axle carrier angle irons and added center rollers both front and rear
