countvlad
Thread starter- Joined
- Jun 29, 2009
- 439
i disconnected the black yellow wire (kill switch) and check for voltage. I had 8V DC from the key switch to the the amphenol connector, with or without the key in the on or off position. Then I disconnected the harness thinking that it might be a key switch problem but the voltage dropped to 4V DC. After I pulled the fuse in the red wire that connects the rectifier to the starting solenoid to the key switch the voltage went to 0V. so that was weird I didn't think that the black/yellow wire should have any voltage while the key was off. then I checked the rectifier side of the amphenol connector and cranked the motor and it showed 225V DC!!!
I also ohm ed the key switch wire to the ground with the key on and off and checked fine...
what do you guys think of this????
