Some 470 Trim and electrical questions.
Rake722
Well things are developing....
New Ex. Mani / Riser,
4 In HE kit and still not had her out :(
2K later I might have a sea worthy boat.
Other than that I need a trim gauge and am confused about the wiring.
Can someone explain how the trim gauge sender and limit switch work please ?
Here is my issue.
Trim up - 50 seconds.
Trim down - 35 Seconds.
Is that the norm ? rebuilt rams too.
Where is the shift interupt switch ?
Where is the trim Sender ?
I am getting a hot wire when trimming up from the solenoid on the pump - its the neg wire and is only 8 amp wire - should it not be 30 amp or more ?
I need to re instate the trim sender and limiter electrics as the wiring seems didgy bvut its all different colors than the manual.
Any help greatfully recieved
Thank you.
a poor englishman.
Re: Some 470 Trim and electrical questions.
Here is my issue.
Thank you.
a poor englishman.
see the attached pic for the shift bracket and switch. See the two wires follow them to the shift interruptor switch.
DonS just posted a link today I think of the wiring directions of new trim senders and limit switch... If I can find it will post it here....
edit...
Check out this link:
http://forums.iboats.com/showthread.php?t=570382&p=3916850#post3916850
see post# 6
Rake722
Thanks Eric,
Mine is older and has a gizmo on the bracket that have 2 wires - grren / black, they both seem to earth and not go anywhere else ? confused. I thought they needed to go into the loom somewhere.
Thanks for the link - sseems my limit switch - port side has no wires explaining at least something. Only Black and red coming through the transom into the engine bay from the sender :( Is this gonna be a bell housing off job ?
Looks like a job and a half this but needs doing.
Are my trim times normal ?
How long should it take from fulll down to full up and vice versa ?
Many thanks.,
Ron.
Rake722
Anyone ?
Thanks
Ron
