jerryjerry05
Thread starter- Joined
- May 7, 2008
- 18,196
Here are a few pics and descriptions on the T@T relief valve repair
You will also need a propane torch and a small pick set..
I managed to get these apart without any other tools
Remove the o-rings and keep them.
You might need to re-use them.
The o-rings don't usually go bad.
Once the tools been modified and the RV and washers have been loaded.
You light the torch and heat only the top a small amount.
Then cover with the rag and try to squeeze.
The cap shold pop out exposing the spring and the washer holder.
You might need more heat????
Let it cool and then remove the bad washer with the pick set.
Install in the reverse order.
I use a small vice to push the 2 pieces of the RV back together.
Be careful a they are aluminum and you can hurt them easily.
