Re: Some Really Dumb Questios I'm Sure !
That was a great explanation ! Thank You..
And that describes exactly what I feel when taking off.
Another Question, My boat does not have a power trim, So If I move the motor stop pin towards the boat does that tend to make it plain soon or later? And by not having a power trim I assume there would be a trade off in top speed or stability etc..?
THANKS TO ALL FOR THE HELP !!!!
How planing works:
You need a planing hull. You have one.
You need enough power. You appear to have it.
When you accelerate, you create a bow wave. You are pushing through the water. You might say 'plowing' the water. Ok. Non planing-hulled boats just keep pushing the bow wave. They just displace water and push through it. They can't build enough speed relevant their size to climb the bow wave and plane out.
As you build speed, you climb up and onto the very bow wave your hull just made, once on the bow wave, you need a little more time or oomph to get over it. You should 'feel' the boat get over it. Engine sends signals too, and you will be able to scale back the throttle and settle in as you are now at planing speed and can run from low-cruise speed to mid-cruise speed up to top speed as you like.
This whole series of events -- known as 'time to plane' -- can be done in as little as 4-5 seconds or up to 15 seconds depending on hull design, power-to-weight ratio, prop size/type, engine trim setting and other variables.
