BonairII
- Joined
- Jun 7, 2011
- 2,727
start with the basics. Check compression, then spark(with adjustable tester in a dark garage etc to be able to see spark...and any arcing from coil).
If you have good spark and good compression, and spark is advancing properly...then check fuel supply. If you bump the choke(while underway) and motor perks up...its a carb problem. Wouldn't hurt to run on a different fuel tank(and diff bulb) to rule out bad tank and/or bulb.
