SonicHub
donzidan
I'm thinking about adding the sonichub to my hds 7 and replacing my current sony cd player. Can any one tell me if I will be able to connect my LWX-1 directly to it (for sirus) and does it have rca outputs. I currently have a amp running four 6 in speakers and two 12" woofers. I would like to keep using my current amp and speakers. Thanks for any help
Boydski
Re: SonicHub
There is an RCA zone 3 out and sub out on the back of the sonic hub that you should be able to use with your existing amp and speakers. There is also a connector for external amp on which may be useful.
Your LWX-1 should connect to the SAT inputs on the back.
Installation instructions with good diagrams can be found at http://www.lowrance.com/upload/Lowrance/Documents/Manuals/SonicHub_Low_IM_EN_988-0183-02_A.pdf
Good Luck,
