Sonofa... I cracked my rocker cover...
slydog75
Ok, so I thought I had a 470 with no leaks at all after changing the head gasket and fixing the coolant leak it had. but now I'm leaking oil because I apparently made one of the screws on the rocker cover to tight (Who has an inchLb torque wrench.. really!) I tried fixing it with jbweld but it didn't work. So now I need a new rocker cover. Where can I find one? I've checked here and Breezeworks with no luck.
slydog75
Re: Sonofa... I cracked my rocker cover...
Any mechanic that knows how not to crack valve covers.
Good answer. And I'll be picking one up before I put the new one on (if I can find one)!
Bt Doctur
A speed or racing shop should be able to get one for a Ford 460 head or your local junkyard
