Suzi55Jet
Thread starter- Joined
- Jun 1, 2011
- 33
Hello! I used to be a member here but daymed if I can't figure out the old user name and password. Been several years.
I just bought a 1977 Johnson 9.9 (10EL77A). It's been in a garage since about 1995 and hasn't run since then. It was running fine when it was stored. $50 with a new prop still in the box. I can't pass up a $50 outboard and I've been looking for something to troll with as my main power is a Suzuki 55 with a jet pump. It's a lousy setup for slow trolling.
So I finally have a kicker motor. I haven't tried to start it.
My plan is to look inside the carb, replace the water pump and probably go ahead and do the head gasket, plugs and a T-Stat before attempting to run it. The motor looks clean and everything that is supposed to move, does move. Am I forgetting anything?
A couple questions before I get the wrenches out:
*I see several different repair manuals on ebay and Amazon. Any idea which ones I should avoid and/or look for?
*Anything I should know about this motor?? Pattern failures, weak links etc?
*I've got a great online supplier for my Suzuki parts, who should I turn to for Johnson parts?
Any help would be greatly appreciated before I start throwing money at another old motor.
