F14CRAZY
Ensign
Thread starter- Joined
- Aug 12, 2008
- 945
I got thinking...my Capri originally had foam on the inside of the engine cover, I'm assuming the stuff that you'd call "eggcrate" foam but with most neglected boats it's long gone.
Does Dynamat and similar material (I've got a roll of Fatmat) work pretty well? Would two layers be needed? I'd like to add some back there to try to keep the noise down.
I got thinking too, wouldn't the insulation you find under the hoods of cars and trucks work well? I'm assuming that stuff is there for sound deadening (and probably heat too). Since it's made for use in an engine compartment I would think it's safe. I'm sure the local u-pull would just about give me a few.
Thanks guys
Thanks guys
