thundercat 9
- Joined
- Oct 8, 2007
- 68
Hi guys,
I have a couple of questions, but first I'll tell you about my problem. I replaced my harmonic balancer on my 87' merc 350/260hp with a thunderbolt IV because the original one had a little wobble, also when I originally set the timing to 8deg BTDC, I used the "mark/line" on the harmonic balancer to set my top dead center(spark plug out and piston at the top of compression stroke...I used a compression gauge in the #1 hole to make sure) and had the "mark" pointing at the zero on the timing tab.
I started the motor and pointed my timing gun at the damper, the "mark" was reading about 6deg ATDC, not BTDC so I set it to 8deg BTDC and took it out on the water. It ran good up to 2000 rpm, anything higher and the detonation got worse. Back on land, I thought the balancer might have spun in the rubber so I decided to replace it. I picked up a chev 350 cid balancer off of an 89 pick-up truck and installed it.(when I compared both dampers, lining up the crankshaft keyway, the timing marks were about 1 1/2" apart, I thought I had this problem licked) After installing the new(used) damper, I fired it up, aimed the timing light and the timing was about 14-16 degrees BTDC.
I pulled the #1 plug and found TDC again, this time I marked the damper with some white out(were it pointed at the zero on the timing tab) and set the timing to 8deg BTDC. Back out on the water we went.....Same problem, this time I loosened the distributor and while my friend increased the RPM, I turned it and the detonation went away and I was able to get up on plane and cruise around 3500 rpm. I did not want to push it any harder as I knew I had a timing problem.
I followed the merc service manual and set the timing the way they say....I'm at my wits end.... would the thunderboltIV amplifier be the culprit. It has A8 22 marked on the side of the box.
Any info would be greatly appreciated.
thanks
jeff
thanks
jeff
