Sourcing parts '89 125 HP
The Force power
The tag reads model# 1254X9B this calls for a (standard) piston part# FA691015 that does not pop-up when searching for it.??
The (date??) stamps on the block "indicate" to a '88 (see pictures attached)
The '88 A & B model piston part# 700-F372015-3
The '88 C model piston part# FA686015
So my question is......................how do I really know what I have? and what piston part# I need?
Many thanks in advance
The Force power
125 (HP) 1989A-1989E piston# F691015
125LD (HP) 1989A-1989B piston# F694015 (also used in 50 HP 1989B-1992A
Does anyone know "LD" stands for?
Nordin
Yes, LD ........ L-drive.
Std piston bore 1988 125Hp should be 3,312 in, in 1989 or 1990 they introduced the 120Hp and the std piston bore was 3,375 in.
I do not think the 125 Hp had 3,375 but maybe the LD had 3,375 bore.
The Force power
Hi Nordin,
I'm going by a BULLETIN - CHRYSLER (1967 THRU 1983) & FORCE (1984 THRU 1998) PISTON/RING CHART
125 HP 1981-1988B 3.3138 Piston part# F372015-3
125 HP 1988C 3.3138 F686015
125 HP 1989A-1989E 3.3125 F691015
My question how can the first two have different part# as they should be the same? or are they not the same?
I added the measuring of the cylinder
Nordin
Do not know why there are different part numbers, I assume the bullentins are OEM from factory.
From my experience all 3 and 4 cylinder Chryslers had 3,3126 bore std and the pistons 3,312 except for the 135Hp, 140Hp and 115Hp mid and late 70es that had 3,375.
I have a 135Hp 1976 and it has 3,375.
Check with Franz at Franz Marine he will know.
Maybe they changed part number when US Marine bought out Chrysler and named it Force or when Mercury went in to Force.
Maybe it is because older pistons had regular squared rings later had semi keystone top ring (triangle angle).
The Force power
Do not know why there are different part numbers, I assume the bulletins are OEM from factory.
Good morning Nordin,
I have attached some reading material for you :)
  • POB-97-06 25-FEB-03 CHRYSLER (1967 THRU 1983) & FORCE (1984 THRU 1998) PISTON_RING CHART (REPL...pdf
The Force power
Both have the same diameter 3-5/16 & used in 3.3125 bore
Both use the same rings
The only difference I see, (on the F694015) the spacing between the top ring & bottom ring is slightly wider.
Could this have any effect OR should I just worry about the position of the top rings being the same & the position of the wrist-pin?
The Force power
Just in case some cares.....I did some more digging and found out;
125 HP 1988C Has regular flat (squared) rings
125 HP 1989A-1989E Has key stone & triangle rings
There is an individual in the GTA area who has lots of Chrysler / Force parts.
The Force power
Update;
Well the "good used" piston with new rings are in.
I have mentioned on a different post that this time;
I did not split the block but did the Re & Re through the intake.
I can honestly say this is like surgery............well maybe not, but a lot harder than a game of operation. :D
Seriously I don't know what is the better route, splitting the block or this way? (at least I can say I did it & see for myself its possible)
My compression numbers are 140 / 138 /140 / 136
The Force power
UPDATE;
Cleaned screens & checked check-valves of recirculation system
Installed new stator / verified trigger (ohms/volt test)
Set-up timing/carbs synchronize timing tower (as per late Frank's procedure /steps)
Compression reading are #1 =144/ #2 =148/ #3 = 150 /#4 = 144
All packs & coils good; spark jump 3/8"
Engine starts right away however it bucked / hick ups
Checked gaskets with starter fluid test as jerryjerry = all's good
Verified firing order (marked flywheel TDC for #1/#2/#3/#4
I noticed when I hooked up a battery to the charging terminal of the rectifier it's slightly less and I "think" I noticed it may of fired twice on the #1 coil per cycle
is this possible?? so what is faulty??
Nordin
The Force power does it fire twice when hooking up a second battery to the charging system and is it charging lower amps or does it affect the spark at all cylinders?
If I do not remember wrong the stator has two or three windings. Two (or one) for charging the capacitors in the CDI boxes and one for charging the battery.
Can you explain more and how you notice possible double firing.
