SP Outdrive Rattle - U-Joints or Exhaust Flap?
rvangeel
I have an SP outdrive that has a rattle when running on dry land.
I have just purchased the boat and have not yet had it in the water. I have found a video on youtube that is exactly the same sound as what mine sounds like. Can you guys have a look at the video and let me know what you think it might be. The comments in the video seem to indicate that it could be u-joints or an exhaust flat which stops water from from going backwards up the exhaust.
Thanks
its an AQ drive shown in the video. not sure of the year, however prior to 1989 from the top cover
however it doesnt help identify WTF is on your boat. so please, identify your drive so we can help you.
assuming that your drive is a 270/280/290....
the rattling is most likely the u-joints.
since you just purchased the boat you need to do all the maintenance that the prior owner neglected for years
again, assuming your drive is a 270/280/290....
in this case, the impeller is easy, its at the front of the crank. takes 3 minutes to change if you have the tools ready
the bellows will need to be replaced
the gear oil serviced
the water inlet casting on the drive will need to be replaced
the water inlet hose between the transom shield and the drive should be replaced
when you pull the drive off, you may find a rusty mess from a leaking bellows. you may not. however prior to using the boat, you need to correct the issue
either way, time to replace the u-joints.
if you have to take the drive in to have the u-joint shaft replace, be prepared for a healthy bill.
if you want to replace the u-joints yourself, be prepared to follow the proper proceedure
  • get a factory service manual (not a seloc or haynes) or at a minimum look at boatinfo.no
  • you will need a method of measuring bearing pre-load torque (a few in the manual)
  • get the correct parts for your drive. use the serial number on top the double-bearing box (just under the steering helmet) you can follow the iBoats link for Volvo Penta parts to take you to either the volvopentastore.com or marinepartseurope
  • you will need 2 new u-joints, an input shaft seal, the sealing thrust washer, double bearing box o-ring and depending on the vintage of your drive, either a stack of shims or the crush sleeve
rvangeel
Thank you for the reply.
The tag on the outdrive says SP-A, 2.15 Ratio, P/N 854011 or 854311 and the 10 digit number is 3102066526.
I cannot use the Volvopentastore.com because I am in Canada and it says only people in the US can use it. I have tried the marinepartseurope.com site as well but cannot find how to identify the model based on the tag information.
Sorry, I am a complete newbie...
Any help would be greatly appreciated.
Would a picture help?
your boat is either a 1989 or 1990
you have a SP-A, also known as a SP290A.
the whole drive is 854011 and your serial number is 31066526
you either have a 230 or 250 motor (4-banger)
so you have a crush sleeve vs shims between the bearings.
posting the images from vp not working.
Figure #DescriptionPart #Qty*Note
Req.
1Upper Gear8540221Also available as an exchange part.
1Upper Gear38031141Also available as an exchange part.
Replaced by
854022
2• Gear Housing8540231Repl by 854571
854571
Replaced by
3856812
3• Stud9418142
4• Cardboard Tube8540241
• Plastic Plug8541981Obsolete part
5• Plug8141791
Replaced by
981965
6• Gasket8976821
7• Hex. Socket Screw9418073
8• Hollow Screw8146431
9• O-Ring9559891
10• Gasket8326691
11• Gear Set8536691
12• Bearing Box8540251
Replaced by
3857144
13• Roller Bearing8539491-183668
Replaced by
3850852
14• Roller Bearing1832471
15• Pivot Pin8527051
• Hex. Socket Screw9418072
16• Hex. Socket Screw9565914
Replaced by
984068
• Washer9425984
17• Pretensioning Sleeve8534841
18• O-Ring9250951
Replaced by
967344
19• Shim853034 TH=0,10mm
19• Shim853035 TH=0.15mm
19• Shim853036 TH=0.35mm
20• Sealing Ring8392531
21• Washer8326751
22• O-Ring9560001
23• Snap Ring9145381
24• Universal Joint8543031Repl by 872089
872089
854615
3858282
Replaced by
3860230
Bulletin P-44-1-5 U-joints
25• • • Joint Fork Kit8535611
854615
3858282
Replaced by
3860230
26• • Lock Ring8533312Obsolete part
27• • • Intermediate Section8977061
872129
3858432
854615
3858282
Replaced by
3860231
3860230
28• • • Fork8543021-839026
872129
3858432
854615
3858282
Replaced by
3860231
3860230
29• • • Spider8532552
• • Lock Ring8533318Obsolete part
30• • Needle Bearing 8
31• • Protector Ring 8
32• • Cork Ring 8
33• Screw8542011SN 3102058853-
Replaced by
3852309
34• Washer8530261
35• Ball Bearing8535422
36• Bearing Sleeve8326442
37• Shim943869 TH=0,05mm
37• Shim946179 TH=0,10mm
37• Shim943870 TH=0.20mm
38• Shim943252 TH=0,05mm
38• Shim943866 TH=0,10mm
38• Shim943867 TH=0.20mm
38• Shim967557 TH=0,30mm
38• Shim943868 TH=0.40mm
39• Shaft8973851
40• Sliding Sleeve8146011
3855783
Replaced by
3807613
3856502
Bulletin P-44-1-8 Shift mechanism, shift cone and shoe
Bulletin P-44-1-18 Shift Cone
41• Spring8139701
Replaced by
3852296
42• Shim264111
43• Snap Ring9510771
44• Needle Bearing8538192
Replaced by
3852390
45• Spacer Ring8973131
46• Lock Ring8973122
47• Nut8393321TH=2,00mm
854228
Replaced by
3852301
47• Nut8393331TH=2,37mm
854230
Replaced by
3852303
47• Nut8393341TH=2,65mm
854265
Replaced by
3852375
48• Shift Mechanism8395041
Replaced by
3855787
49• • Bearing Housing8395051
Replaced by
3855785
50• • Eccentric Piston8978161
Replaced by
973593
3856008
Bulletin P-44-1-7 Shift mechanism, eccentric piston
51• • Dog8146031
Replaced by
3856502
52• • Spring8141841
53• • Screw8977111
54• • Shim897871
55• • Sealing Ring8538681
56• • Spring Pin9519241
57• • Clevis Pin9428711
58• • O-Ring9250931
59• Hexagon Screw9401694
60• Bellows Kit8758261Repl by 876294
Replaced by
876294
61• • Hose Clamp8530131
62• • Hose Clamp8530121
Replaced by
22274887
63• Oil Dipstick8393511
64• O-Ring9559741
65• Type Plate8537061
Replaced by
3817315
66• Drive Screw8042692
67• Anchorage8541791
68Cover8540361Included in complete drive unit
Replaced by
854605
• Locating Pin8541801Included in complete drive unit, Obsolete part
69Screw8546611Included in complete drive unit
70Sign8541371Included in complete drive unit
876508
876635
876509
Replaced by
872867
872995
872868
876636
71Sign8541401Included in complete drive unit, P
876508
876635
Replaced by
872867
872995
872868
71Sign8541411Included in complete drive unit, S.B
876508
876635
Replaced by
872867
872995
872868
72Sign8541441Included in complete drive unit
you will need the proper volvo penta manual to pull your drive apart to replace.
