spare fuel tank
tav
want to add this as an extra o the lake
thinking of going with 4" high aluminum angle to keep it tight in place.
is there a special kind of stainless steel screw I need to get for this composite
hull? don't want striping out. sorry it's side ways.
Woodonglass
Re: spare fuel tank
I'd probably recommend toggle bolts or glassing in a cleat
tav
Re: spare fuel tank
I get the toogle bolt idea....but the cleat part I don't understand.
Re: spare fuel tank
Ayuh,... A block of wood, glassed in, to screw into,...
I'd go with an eye bolt in front of, 'n another behind,...
Then just stretch a bungee cord from 1 to the other, to hold the tank, in-place,...
jbcurt00
Re: spare fuel tank
Fiberglass a wooden cleat on top of the deck under where you want to mount the angle to hold the tank. That raised lip would help hold the tank in place.
Make sure to allow for a plastic tank to expand & contract in the sun/heat when you attach the angle/cleat to the deck and whatever 'system' you use to tie the tank down. I wouldn't put a square cornered aluminum angle tight to a plastic tank.
tav
Re: spare fuel tank
Bj....sounds like what I'm looking to do. I'll keep this in mind. Thanks
tav
Re: spare fuel tank
Will glass hold on a textured floor or do it need to be smooth.
I have some glass left over from a job I did on my truck .
jbcurt00
Re: spare fuel tank
Not w/ out roughing the textured deck up 1st.
