Car Guy Buys Boat
Thread starter- Joined
- Sep 8, 2010
- 4
I have a 55HP 1968 johnson motor 3 cyl 2 stroke. It has the point ignition with electronic amplifier.
I am ditching the distributor cap, electronic amplifier, coil, and converting to coil on plug ignition with a crank trigger. I need to program the spark advance curve.
I have a manual and cannot find the following:
Ignition advance curve profile,
what is the total advance at full throttle,
and for sake of argument, what is the timing at idle to be set at.
A table would be very helpful, for example:
600 rpm = 6 degrees ATDC
900 rpm = 4 degrees ATDC
1200 rpm = 2 degrees ATDC
1500 rpm = 0 degrees TDC
1800 rpm = 2 degrees BTDC
3500 rpm = 25 degrees BTDC
4000 rpm = 28 degrees BTDC
4500 rpm = 28 degrees BTDC
5000 rpm = 28 degress BTDC
Thanks to anyone who might be able to help with this missing info.
