trikefloats
Thread starter- Joined
- Oct 7, 2008
- 5
Hi folks,
I have some experience with Rotax ultralight engines, and when I had these symptoms and I know it is not a fuel problem, because I have two cylinders getting fuel from single carb,and the other is running fine, that usually means crank seal leak. But with outboard engines a friend of mine told me that he has heard, that the cooling water may do these problems on the bottom cyl if the gasket is leaking. I will inspect the reed valves today.
Any ideas before I remove the power head to change the seal? Any tests that I can do? THANKS IN ADVANCE.
