timharper89
Thread starter- Joined
- Jun 24, 2018
- 277
1987 4.3 mercruiser s/n 0B459735. Just put as new distributor and rotor and spark plugs in. Had it out on the water today and noticed it was as bit sluggish. Also heard a ticking noise. Then the boat wouldn't stay on plane without being at wot, so I decided to idle it back to the dock. Then it stalled at idle, so I had to keep it about 1200 rpm to keep from stalling. When everyone was off the boat I lifted the engine cover and saw the ignition coil arcing from somewhere under (or through) the boot to the ground screw on the coil. I'm grateful that there weren't enough fumes to cause a disaster. I did not change the wires this year. Is there any reason, other than an old wire, that this would be happening? Figured I'd change the wires, but maybe there is something else to check out. Thanks
