Spark at plugs, but cyl not running
Troyb56
Ok, here we go again. 1971 60hp johnson. I had cyl 1&2 running and 3 not. Took off carb and got fuel to number 3 now. You could pull off plug wires off 1&2 and engine would bog and 3 nothing. Now only cyl 3 is running and 1&2 you can pull plug boots off and motor does nothing. There is spark coming to all plug boots when i check each plug wire. Any help is really appreciated. Thanks
Monte1961
Re: Spark at plugs, but cyl not running
Are the plug-wires right?
Borgey401
Have you tested how strong spark is on each cylinder? Also, have you tested compression on each cylinder?
Troyb56
Yes all plug wires are right and compression is great on each cyl around 135. I just bought the tester to check spark length, but all are fireing when checked with plug outside cyl.
Monte1961
Is it a possibility that key-way is sheared? Just a thought.
Troyb56
Idk, but I had one mechanic set the points and rebuild all 3 carbs, but said he couldn't pinpoint why the one cyl wasn't fireing but getting spark, since then the one that wasn't fireing is and the other 2 not. At first I thought that I just had a fuel problem on the one that wasn't fireing because plug came out dry and clean, since then that plug is wet and is the only cyl that is running.
