Spark CORRECT WHEN VRO ELIMINATED AND YEAR
erick11s
.I just bought a Robalo 25 with two motors evinrude ocean pro 225 each, the two engines have the VRO ELIMINATED and work with pre mix oil with gasoline 50/1, the situation is that a one motor is year 1994 and the other is 1998.
I have two questions-
1: What spark plugs are correct for each engine, for 1994 and 1998 year.
2- The factory recommended spark plugs " Q " are designed to work with Vro.
What is the best spark plugs should be used when working with pre-mix 50/1
Thanks in advance
Erick
Faztbullet
(1).....Champion QL78YC
(2)...The QL is for Rf noise supression ,wont matter if it has VRO/OMS
The oil mixing unit in service mixes the oil with the gas.-------If you mix it yourself it amounts to the same thing.---Never mind what the link says !!
