Spark Plug Choice 1987 XP150 Evinrude
muchco
Just wondering the merit of surface gap plugs? I have been told that they are only designed for sustained high speed operation, any amount of idling and they are useless. What plugs work best in this motor?
bubbakat
Re: Spark Plug Choice 1987 XP150 Evinrude
all i am showing in my book is a UL77V OR QL16V<br />Which both of these plugs are surface gap plugs
muchco
Was that UL77V or QL77V. My understanding is that the Q is a resistor type plug.
bubbakat
That is listed as ul77v you are right on about the Q being a resistor type plug.
Dhadley
You can also use the standard (Q)L77JC4's.
muchco
Thanks, It's probably advisable to stick with the resistor type plug? Any preference between the surface gap QUL77V and the standard QL77JC4?
walleyehed
The std type, QL77JC4 will Idle a bit better, but if most of your time is spent at cruise or high-end, the surface gap is great.
muchco
Thanks, for the advise, greatly appreciated.
