Black as
Thread starter- Joined
- Feb 22, 2010
- 417
Hi Guys
I had a chance over the weekend to do a spark plug test on my 5.7 litre Vortec engine running a 4 barrel Rochester, engine has done 20 hours total and in both cases the plugs remained the same colour. One test was done at 2800 rpm and the other was done at 4500 rpm. My thoughts are it's a little lean side and from the reading I've done my thoughts are is to increase the size of the jets in the primary only and leave the secondaries alone, what do you guys think, see the attached photo Also while out on the water I then went to WOT and the RPM's went to 5200 rpm so I backed off, also what are you thoughts on this as well.
