Spark Plug Gap Setting
Algielong32
1984 Johnson 140hp V4. I need to know the gap setting or should I use the bullseye marine plug? Which Is Better?
WillyBWright
Re: Spark Plug Gap Setting
.040 and what is a bullseye marine plug?
edit: Oh, you mean a surface gap. Those are best for sustained high speed operation. Conventional plugs are better for all-around and low speed operation.
OBJ
I believe that the recommended plug is a Champion UL77V....which is a surface gap.
At any rate, use only the recommended plug.
Walker
I know a lot of people on this board recommend .040 gap, but I've always gotten better performance on the V4 crossflows throughout the throttle range gapped at .032
