.030 ". But you should be using Champions as the mtr was designed for them.
thanks for the info, having problems with the plugs not lasting very long and the guy at our local boat shop said for me to give the ngk a try![]()
If the guy at the "local boat shop" told me to try a different plug than what the manufacturer recommended... instead of trying to find the reason the motor is eating plugs, I'd find a different "local boat shop"....:facepalm:
What did the plugs look like that "did not last very long". The plugs' appearance can tell you a lot.....if you look and listen.
Thanks for the advice Tim! Tim i do have a very small miss during idle, took the plugs out and took one to the boat shop and thats when the guy told me its the junk plug, the champ plugs go bad all of the time! Most all of the plugs had a lot of black on them not much of the plug looked clean. I do need to try to find someone else to take it to but around here i dont have many to choice from. Any help would be great, the motor runs very strong when you put the gas to it, if i just idle around for a bit and give it gas it is a little sluggish at first but runs out ok, also at idle it may die and it seems harder to start at fisrt but once you start it once for the day it seems to start ok, hope this makes some since, Thanks!!!
JB. Most service stations and garages had them back in those days and you could take your plugs into them and have them cleaned for little or nothing.
A little troubleshooting goes a long way.
A simple compression test along with a spark gap test tells you a lot about the condition of your motor. When both tests confirm a healthy motor begin to dig into the fuel system as carbs DO get dirty, causing issues that can soon destroy an otherwise fine motor.
Clean carbs, be sure to order new carb rebuild kits, never re-use bowl gaskets, rebuild the fuel pump, replace all fuel hoses, adjust carb linkage and timing EXACTLY as spelled out in the FACTORY service manual.
