2009 5.7 L MPI
Original plugs were iridium gapped at 0.06.
Will any harm be done by crossing to a conventional plug with a tighter gap?
Reasoning: I have been having a moisture problem and I think the small tip of the iridium with the wide gap is creating a spark issue at start-up. If I pull the plug after sitting for a few days it has moisture build up. I am hoping with the larger surface area of a conventional plug and a tighter gap may eliminate the problem. I am just not convinced that I will not create an another issue.
