I disconnected wires to change plugs and I do not know what sequence they go back in. ( What plug goes where on distributor cap) Mercruiser 135.
Mercruiser does not have a "135"
Give the guy a break. You know he's talking about a 3.0.![]()
SN, Model number, Year, etc. will get you an answer.
On any engine, unless you know the distributor has NEVER been removed, you have to find #1 Cylinder TDC on the compression stroke. Then look at where the rotor is pointing. That is where #1 plug wire should be.
