Spark Plug Wire Set?
BigDaddyPJS
I have a 1992 FourWinns Horizon powered the a 5.8L OMC with a working, dreaded, Spitfire E.E.M. system. I am unable to find a spark plug wire set for my engines year and setup. I have seen where Sierra makes sets for the 5.8L up to 1990 and a look at the BRP site show all the wires as NLA. Does anyone what would work for my setup.
MRS
Re: Spark Plug Wire Set?
I got a set for mine not the same as yours but for omc from summit in there marine section. I could not find what I needed at the time and they did have them plus the right tune up kit. Hope this helps...
Ayuh,.... There's really nothin' Special 'bout marine plug wires....
Except the ends gotta match what ya need, 'n they're long enough....
You oughta be able to find "End Kits" that match whatever ends ya need, 'n a crimpin' tool....
Then buy a reel of quality hi-tension plug cable, 'n Make yer own....
MRS
Ya, I also have the mallory wire kit works great when you need to make your own set. Can custom make to fit where you need them.
