spark plugs
funship
I have a 05 Four Winns 234 Funship with a 350 MPI, how often should the plugs be changed ? At 18.50 a pop from my tech. it seems a little pricey. Thanks for any inputs.
abj87
Re: spark plugs
only when there worn... could be 400 or 1000 hours.
cr2k
Re: spark plugs
My 5.3 chev truck book sez after 125,000 miles, I now have 106,000 and that is 3080 hours.
So I would say you could go a 1000 hrs or so.
Gary H NC
Re: spark plugs
Depends on what plugs it uses.
The Chevy truck plugs are platinum tip and yes they say 100,000 miles..:rolleyes:
The AC Marine plugs are not platinum plugs.
You can get the AC MR43T at Rockauto.com for under 3 bucks each.
They are the marine plugs and probably the exact plugs the dealer is telling you are 18 bucks each.
45Auto
Re: spark plugs
I just changed the plugs in my 2003 MPI for the first time because the last time we were out I felt a tiny miss until the engine warmed up good. Had just under 250 hours on them. They still looked brand new.
You don't have to buy the plugs from a marine outlet. Factory plug for your engine is the AC 41-993 (per this Merc bulletin, the 993 is the equivelent replacement for the 932):
http://www.justanswer.com/uploads/ROCKETBOAT/2008-12-09_042519_SPARK.pdf
You can buy them for $19.30 EACH at a typical marine outlet like this:
http://www.mertenmarine.com/servlet/the-682/MerCruiser-Spark-Plug-884019001/Detail
Or you can get them at an auto parts house like Auto Zone for $6.49 each. Your choice.
http://www.autozone.com/autozone/ca...33-0&displayName=Spark+Plug&searchText=41-993
funship
Re: spark plugs
Thanks for the input guys. I did a little research and the price is correct. They are platinum tip, copper core and should be good for 300 hours. I guess my mechanic "upgraded" me from the stock plugs. I had 105 hours when service was done so I'll keep track of plug life. Thanks Again
45Auto
Re: spark plugs
Platinum plugs at an auto parts house are $6-$7. The Iridium plugs are a little more expensive. Do you know what plugs he put in? May be a little more reasonable to get them yourself next time .....
