spark plugs
JJB61Jon
1989 Yamaha 175 2 stroke, sticker in motor says B8HS 10 and online charts say BR8HS 10. Should I go with the resistor plug ?
99yam40
back in the good old days I think they put resister plugs on cars motors to help reduce the radio noise
I am not sure why they went to R plugs on boat motors
Sea Rider
BR spark plugs are excellent if will be using electronic toys on board, if not the B8HS-10 will work OK gaped tight to 1.0 mm...
Happy Boating
JJB61Jon
I'm green coming into outboards, I'm awaiting my Yamaha service manual.The charts online for plugs are different. I saw gaps on charts from .43 and also .04. You mentioned gap to 1mm, is that the same as .04 ? The plugs in the motor are gapped at .30 to.40, so this would be incorrect. Could the wrong gap(excessive) cause a rough idle but run like a champ 1/2 to full throttle ?
Faztbullet
Before super dooper fishfinders and GPS units it was fine to run non resistors. If you have not been having any interference problems use the non resistor plugs. 0.04 =1MM=.039 so plugs are gapped correctly.
Sea Rider
If Yam calls for NGK B8HS-10 those recommended spark plugs must be used. The side 10 stands for 1.0 mm factory gapped, if without an ending number are usually gapped to much less say 0.7mm...
Happy Boating
