Hello,
I have a BF9.9 Ithink its a 93. Iusually run it about 20 hours a year.
I bought this boat in 1997 used. Oil has always been kept fresh.
With clean plugs and last years fuel, I am having extreme difficulty starting the motor. after a while it will start, run for 30 to 40 mins till I turn it off but will not warm start again, or if it does its intermittent and not consistent.
The plugs look extremmely fouled after it is shut off mainly carbon as I had put some seafoam in the tank last year.
I usually store this boat for about 9 months out of the year, and I do not drained the carb from all the fuel.
I am puzzled if this a spark issue or a fuel issue.
When I take one plug out and connect the plug wire to it then ground it to the engine case and crank the engine I am not seeing any spark at all, do I need to ground both plugs to test this?
as for the carb mixture setting I am a bit unsure on where that needs to be. I have it about 3/4 ways in and it did start.
I had gapped teh plugs to .023 to .024 and there was no consistent results.
since I have owned it it has started every time without any trouble, so I am wondering if something is starting to go?
any help is appreciated..
