Faztbullet
- Joined
- Mar 2, 2008
- 15,938
Re: Spark Problem
This is a very simple ignition system, check your DVA voltage on the high speed side of stator(blk/wht) and see if voltage falls off, if so stator is bad. If it is steady the rectifier inside switchbox is bad. All readings are from imput to ground....
