Re: spark tester
I just bent down the tip of the electrode and looped the wire around. Where the wire goes through the nut that holds the spark plugs, I used a die grinder and ground a small slit in the nut so the wire will go straight out. Then put on RTV to help hold it and seal it off.<br />All together, it took me about 30 mins. to build.
