Sparking, sputtering rpms at high idle?
erikpn
87 Force 35. What could it be? It seems to idle low ok. When I put it on high, I get misfires and the rpms fluctuate. I also sometimes see sparks flying from the stator to the engine block on the side where the ignition wiring is.
pnwboat
Re: Sparking, sputtering rpms at high idle?
Sounds like you have some wires that may have the insulation worn off from touching the flywheel?? You shouldn't see sparks.
