Merc90HPnewbie
- Joined
- Jul 27, 2003
- 178
Ok so I went to 'winterize' the boat this saturday. Long story short I got the engine started, removed the fuel line, and sprayed Quicksilver "Quick seal" (or whatever their fogging spray is called) into each carb. I have a 1985 90 HP straight 6 o/b (three carbs). I let the engine run until it died of fuel starvation. Oddly it was running pretty well on the diet of whatever gas was left in the carbs and the fogging fluid I was spraying in. I had posted here a long time ago about the wisdom of doing this (will some carbs run out of gas before others, making some cylinders pump up and down with no lubrication? The response was a definite.... "maybe" so I figured I would try it out). Then I go to pull the plugs and put the fogger in each cylinder. All the plugs have at least some brown oil on them which was OK considering I sprayed a lot into the carbs, but the fifth one from the top was totally CLEAN. I mean, it almost looked like I just got it from the store. Unfortunately I had never pulled all the plugs before so I dont have much to compare it to, but it made me nervous. And that cylinder was definately running hotter than the rest. Putting my hand over the open sparkplug holes, all the rest were cold and this one had a noticible amount of heat coming out. Not so hot I couldn't stick my pinkie in there but it was warmer than all the rest.<br /><br />So, is this a case of one cylinder running out of fuel (and the accompanying lubrication) and getting a little warmer? Or could this be a dead cylinder? What should I look for? <br /><br />Thanks for any replies. I'll try not to freak out about this all winter
<br /><br />PS Some grey (gray?) sludge oozing out from exhaust after the above procedure. Is it safe to assume that's just partially burned foggoing oil?
