sparkplug wire removal/misfire check
yourkiddin
i own a 2003 75 mercury. i suspect a miss or skip as some call it, i call it a miss. anyway i just got it and was wondering if you can check this engine the same as my older car? and that is remove a wire and see if there is a change in the idle. i have done this and only seen a drastic change on the #2 plug. removing the other 2 i really dont tell it doing anything. now when putting them back on i here the spark and it may run just a hair smother. but not much. i already changed the plugs and saw no diferance.
Re: sparkplug wire removal/misfire check
Sure, Sounds like ignition or carb problems on the other two cylinders.
yourkiddin
was wanting to replace the wires but it looks as if theres more to it than that. whats the littlle black box at the end of wires?
yourkiddin
so can i replace the wires first or is it one asembly? i already ran a gallon of gas with stabil in it. it helped alot,some say to use sea foam. but i also read on here that sea foam and stabil has 95% the same ingrediant.
yourkiddin
heres an idea. what if i just swap the coil and wire out with the good one to see if there is a change. how hard is this?
yourkiddin
last night i swapped 2 of the coils and saw no improvement. i put a spark tester on all the wires and the spark looks good.
