Re: Speaker amp suggestion
i do car audio as a side job and I've done a few wake tower set ups. as far as the speakers that you have they run at a 130 watt rms at 4 ohms. to find the amp you want to combine the rms power and not the max power for longevity of your speakers. i'd recommend a cadence f200-2. its a 2 channel amp. 2 channel meaning you can hook up 2 speakers and you can bridge them together to obtain maximum out put with out damaging sound quality and speaker longevity.
Audio Savings | Cadence F200-2 High Power 500 Watt Peak 250 Watt RMS 2 Channel Car Amplifier Amp
to bridge an amp you must Locate the speaker outputs of the amplifier. Then look for the word "bridged." If it appears, it will point to two of the speaker output terminals, one marked "+" and the other marked "-." These are the speaker outputs that you'll use when using the amp in its bridged mode.
Cut a length of speaker wire long enough to reach from the amplifier to your first speaker. Strip the insulation off of the ends of each end of the wire so that each lead has 3/8 to 1/2 inch of bare wire exposed.
Connect the wire to the "bridged" outputs of the amplifier. Connect the positive lead of the speaker wire to the "+" terminal, and the negative lead to the "-" terminal.
Connect the other end of the wire to the terminals of your first speaker. Connect the positive lead of the speaker wire to the "+" terminal and the negative to the "-" terminal.
Cut a second piece of speaker wire long enough to reach from the first speaker to the second speaker. Strip the insulation off of the ends of the wire so that there is 3/8 to 1/2 inch of bare wire exposed.
Connect the second piece of speaker wire from the "+" terminal of the first speaker to the "+" terminal of the second speaker. Repeat the process with the "-" terminals of speaker one and speaker two. if you have done this correctly then you will have crystal clear sound for a long time. hope this helps
