Speaker Holes Question.
Boatdrinks
Re: Speaker Holes Question.
Are your panels in different colors? I have seen Bayliners with the screws hidden in between the colors on the vinyl. Check the seam areas...
magster65
I have a pair of Infinity 5 1/4's in my boat hooked to a Pioneer mp3. I added an MTX 300 watt amp and a 10" Fosgate sub I hid in the bow. Holy crap it sounded good! That system wasn't terribly expensive and I can't see why you'd need anything more. I find that more often than not, it's the type of music you play more so than the volume. I like most music but prefer heavy metal (Pantera, Rob Halford... etc.), not many other people listen to that so when I'm around the marina I slide in some Eagles or something like that... oldies are always popular too. Gotta' keep the peace right? As soon as we're out of port though... I let 'er rip with a little Cowboys From Hell or Contortion... some really good tunes! <br /> :) <br /><br />I got an idea for a post with this... Dockside Chat
magster65
I just thought of something else... if you get a sub, get a 10" and get the 'tuned' boxes that are available (if it'll fit). The 10's sound better than any other. The 12's don't have as good of 'thump' at low volumes and the 8's won't fill the boat up with music as well.
code p1mp
A couple of things here:<br />1.) taking of your walls is not only a waste of time, but you will not easily be able to get them on as well as the fact that most boat manufactures place thier securing screws in through the wood then vynil over them. you will end up getting all the screws out (after much swearing and cursing with a 90 degree drill bit) and discover that something is still screwed in and you cannot find it... that something will be the 3-4 anchor screws the factory put in to hold her in place while they vynil down the side. to truley remove the walls without redoing their vynil, you would have to pull the staples out of the vynil seems to get to the wall anchors.<br /><br />2.)There are these things called razor blades, use them with the 6x9 template that comes with the speaker. remove the old speaker and tape the template over the old speaker hole. cut around the template with the razor blade tracing the lines. now your vynil is cut to spec, just drill a hole at one end then finish cutting with a jigsaw. Sorry to sound matter of fact, but I can't stand it when people tell people to remove the engine to change thier oil...<br /><br />As for "Boom Boom" lake people, thats why boats have motors. If someone has a loud stereo and they are bothering me, I rooster tail em' on my leave or simply flex my 2000 watt system (just a smidge) but it usually puts those silly wakeboard tunes to shame. 6x9s will sound great, just make sure they are mylar based not paper to avoid rot.. (do they even make paper speakers anymore??)
wingback
Probably a little late for you now. But I just thought that I would mention that they make 6x9 speaker boxes. I dont know your boat but its very possible that you could just tuck those in the cubby holes and then replace your round speakers with the same size. Though if you're adding speakers I would definately go with an extra amp.
Cayo Boater
Does anyone know where I can purchase speaker grills (covers) for speakers already installed on my boat. The covers/grills on there right now are cracked (appears from some hard leaning or child's play).
