Went out last weekend for a little fishing excursion... As I pull up to the ramp there is a guy trying to back down the ramp. He was a good 150ft from the ramp and would literally back up like 4 inches and then pull forward 3... Over and over... over and over....
I get out and get the boat prepped for the water... Get back in and he's literally only about 10ft closer to the ramp than before I started!!!
I was about ready to jump out and help the poor guy, but then the other ramp (there's two there) opened up so I went ahead over there... I back down, float the boat, tie it off and jump back in and park the trailer...
Come back, get in the boat and he's JUST getting it into the water...
What do you think happens next?
You probably guessed it... He jumps out and THEN starts prepping the boat... Getting the drain in, getting the tie-down off, etc...
Anywho, I head off up the river... Go a ways and decide to head back down river the opposite direction... As I'm passing by the ramp I look over and notice the SAME guy still struggling to back down enough to get the boat off the trailer... Good GRIEF!
Head down river a ways and set up to start some fishing... Cover a nice area that looks like a good bass spot and find nothing... Didn't feel like waiting for the draw bridge so I head back up river again... About 500ft from the ramp I pass the same guy... JUST getting shoved off away from the dock!!!
I mean come on... Backing up the trailer is bad enough... If you suck at it that much either bring along a friend that can do it, or go out to a parking lot somewhere and get lots of practice!
But then to add insult to injury, to not even have the boat prepped before tying up the ramp?!?!?
There outta be a standard "ramp rules" sign at every ramp... I can't tell you the amount of times I've seen folks do the same thing... Have some curtesy for others and if you can do it before backing down the ramp, DO IT! It's just common sense...
Things happen... Sometimes it takes longer to launch than others... I have no problem with that, but for goodness sake at least do what you can to minimize your time...
Okay, my ranting is over... Thank you... Please drive through...
