bhughes
Thread starter- Joined
- Apr 28, 2009
- 57
I'm trying to figure out if my throttle is working properly before I go and clean the carb.
The issue is that when I give the motor throttle, it starts to go but at about 1/4 the way up the throttle, the motor doesn't go any faster even when I pull the throttle all the way.
While inspecting the throttle and carburetor, I can see that when I pull the throttle, the cable pulls on the throttle shaft which is connected to the carburetor. This seems to be working fine. But, I notice that there is a "Link" that is connected to the throttle shaft. This link is also connected to the Bellcrank which moves the choke valve thing. Anyway, when I pull the throttle, is the link supposed to move with the throttle shaft and move the Belllcrank as more throttle is given? Currently, when I pull the throttle, the throttle shaft just slides on this Link, and therefore the link doesn't move the bellcrank at all. If this is how it's supposed to work, then I don't see the purpose of this Link.
If you look at this diagram, I am referring to parts 12, 54, and 14.
http://shop2.evinrude.com/ext/index.aspx?s1=2fe15ff59bf5d2bee73f248e0d6ad99a
If someone could tell me if the bellcrank should be moving that would be great. Thanks!
