specific winterization questions
skysurfer2010
I did a search and couldn't find the answers to my questions. Sorry if they've already been discussed.
I used my boat probably around 5 hours this season (10 max). Most of my time was spent cruising to a spot on the water 10 minutes from the dock, sitting there for hours, and then driving back to the dock. The oils in my engine and outdrive both look brand new with no water in them. Is it really necessary to change them since they look brand new still?
I paid a mechanic to winterize my boat last year and he used a bucket filled with antifreeze connected to the muffs to put antifreeze in the block (after draining it of all the water). I've also read about pouring it in manually after draining it. What hoses do you pour the antifreeze in? Is there a right or wrong sequence in which way you fill the hoses up?
Sorry if the second question has been debated/ and or asked multiple times. I'm just unsure about leaving it dry through the winter. It's stored outside through a brutal NJ winter.
skysurfer2010
Re: specific winterization questions
In regards to the oil... I just got a new job and will be going away for 2 months of training. During training my pay will be next to nothing so money is super tight. Normally I'd air on the side of caution and change them just to be on the safe side, but any money I can safely save right now would be very beneficial.
thumpar
I also believe in the air don't freeze thing. I have never had a problem and it gets cold here for long periods with boat stored outdoors.
skysurfer2010
Thanks guys. I did read both of those threads when I did a search. My only concern is either not getting all of the water out or possibly corrosion. I guess I'm leaning towards not putting the antifreeze in.
Thanks for the help.
