Specs for external "shop" tachometer
ShoalSurvivor
I'm looking to pickup a shop tach to adjust idle and set timing on my 2004 Mercruiser 4.3
Will one of these $20 "small engine" tachs to the trick?
Amazon Tach
are they all "pulse" tachs?
I'm looking for a wired version to connect to tach pigtail on the harness (purple / grey), but the all show clamping into or wrapping the spark plug wire.
Recommendations and instructions for hookup would be greatly appreciated!
thanks,
Michael
Scott06
Amazon Tach
thanks,
Michael
normally a shop tach is for temp hook up either on a plug or the negative side of the coil. if you need a timing light I would get a timing light with a tach. I keep waiting for my old dial back timing light to die (1990 vintage...)
I bought this because it also does the KV of the spark which can be helpful when trouble shooting , but its a little pricey. Nice that you just hold it close to the engine and can do any cyl or stroke combo ..
this has a tach feature also is a VM-
dingbat
I have one similar to the one posted. Use
Amazon Tach
i use one similar to the one you posted to adjust idle on my small, two and four stroke engines.
Came as a “wrap around” but added a battery clip to make it a “clamp-on”. Works well for the purpose. No complains for the price
I have a laser photo tach I use on 2-strokes
I have 5 old tach / dwell meters that I use. One of them was my father's from the 60's, one is mine from the 80s, and the other is from my wife's late father and 2 from a garage sale. Paid $8 for the last two about 2 months ago
My recommendation is hit your local garage sale
Scott06
Same here the sun tach and dwell I bought in 1990 ish died, so I use my fathers that he bought in the 60 s, still works. garage Sales and FB market place are good places to look.
