Re: Spedo pitot on 89 80 Merc
The easiest one to check first is the speedometer that works on compressed air in the line caused by the water pressure from the pickup. Just shoot some LOW pressure compressed air into a line connected to the fitting on the back of the speedometer. Vary the pressure if possible to check the movement of the indicator. If that checks okay, then put your boat in the water with the water pickup line to the speedometer disconnected from the meter end. Put it somewhere you can monitor and see if water is being pushed through the tubing when the boat is underway. That should tell you where the problem is. Good luck.
