Re: Speedboat Restoration
Yes epoxy is probably the best adhesive to use, certainly if you make a stitch & glue boat it's really the only glue to use. If you build a more traditional ply on timber frame boat though you may want to consider using Balcotan polyurethane adhesive from Robbins, it can be used in much lower temperatures than epoxy, is slightly cheaper, and is used straight from the bottle (no mixing). With winter approaching this may be an important consideration, you can't work outdoors with epoxy in low temperatures, so you'll need to have somewhere undercover that can be heated, like a garage or large shed.<br />Using polyurethane you could just construct a large polythene shelter and carry on working outdoors, which is exactly what I did last winter.<br />You can't waterproof the boat with it though, for this you still need epoxy for maximum durability, but if you don't need the boat to last for ever you could just paint it instead.<br />There are many ways to save money, but most result in a boat that needs more regular maintenance, so you save in the short term but it costs you more in the long term, the choice is yours.<br />Before you rush into buying exterior ply though do check out the prices and make some comparisons with marine ply. If you go with exterior you MUST get the best grade available, and check that it really is exterior grade, it should have WBP stamped on it which means Water and Boil Proof. Don't accept cheap exterior ply which may have filler in the surface, you don't want this in a boat!<br />Marineply.com have Far Eastern Marine Ply for as little as £14.62 + VAT for a sheet of 6mm, top quality exterior ply will cost you MORE than that! By the time you add delivery there will probably only be a few Pounds in it.<br />Please don't forget when you are trying to save money on your boat, that your life, and the lives of your passengers, may well depend on those few extra Pounds one day, this is a serious consideration!
