speedi-sleeve
LUVMY470
Speedi-sleeve on the cam. Lock-tite or no lock-tite....that is the ?
dingbat
No lock-tite.
Use a "sealant" between the shaft and the seal to prevent moisture from getting under seal
  • Shallow wear grooves do not require filling. Optionally, a light layer of a non-hardening sealant can be applied to the inside diameter surface of the sleeve. Clean away sealant that migrates to the shaft or sleeve outside diameter surface.
  • If the shaft is deeply scored, fill the groove with a powdered metal epoxy-type filler. Install the sleeve before the filler hardens, enabling the sleeve to wipe off any excess filler. Clean away any remaining filler from the sleeve outside diameter surface.
achris
More fish than mountain goat
Speedi-sleeve manufacturer recommends Loctite 518, Master gasket sealer. It's the one one recommended for sealing up the crankcase halves on outboards. It's semi-hardening...
Chris.......
welcome aboard.
on future posts, please indicate what you are working on.
we only know because the 470 is the only motor that would ever need a speedy sleeve on the cam.
LUVMY470
10 4...mercruiser 3.7lx. Got a great deal on a 1986 wellcraft american 180. Been working out the kinks. This forum has been awesome for info. Its my first i/o...guess i needed a hobby LOL. It sat for a couple years. ive put about 20 hrs on it since may. Water pump seal finally went. Think i got it all ready to go back together. Been learning ALOT about boat motors! Thanks for the info
LUVMY470
photo298377.jpg Cam looks pretty grooved. Should i use a metal filler? What about permatex steel weld epoxy? Its going on 1 time and 1 time only right?
achris
Use the loctite and those grooves will be covered up... As there is enough metal either side of the grooves for the speedi-sleeve it will 'seal' there....
Chris........
