Speedometer 4MPH Off According To GPS
dtescher
Mt speedometer is off by 4mph according to my GPS. Is there a way to test speedometer? It's original to the boat. 1997 Reinell 4.3GL PLKD #4110144649
matt167
Re: Speedometer 4MPH Off According To GPS
4 MPH is nothing. Supprised it's not reading 10 MPH or more off. Normal boat speedometers are not accurate and that is why the market is switching to GPS speedometers. The speedo you have is basically an air speed gauge that measures air pressure. The water pushes against the air in the tube and makes it work, but they are never 100% accurate
Don S
The speedometer for your boat has nothing to do with your engine or drive. It's just a pressure pitot tube mounted on the transom. Very inaccurate.
Nickypoo
Yes conventional boat speedometers measure stagnation pressure at the tip of a pitot. This isn't a very precise way to measure speed but it's simple and reliable.
GPS speedometers are more accurate, but only on land. What you are seeing on the GPS is your speed relative to land. You could be in a current where your water speed is different than the land speed. In this case the pitot may be more accurate.
Don S
You could be anchored in a 10 mph current with the engine off, and the speedometer on your boat would show 10 mph. But you are anchored and going nowhere. The GPS gives you speed over the ground, the speedometer gives you speed the water is passing the pitot tube.
dtescher
Good enough. I won't worry about the difference then. Thanks for the info.
82rude
another name for them is lie o meter.
rallyart
I thought the Lie-O-Meter was the fuel gauge. :confused:
rallyart
Oh well, at least I know that Port means a red wine. ;)
etracer68
Ensign
And not to be confussed with, RED, "RIGHT", RETURN.
cuenta
My brother made ​​a bigger hole to pilot tube connection
to trick the speedometer
he gain 10 MPH
jajajajaja..
tpenfield
FWIW - I have found that the pressure speedometers are most accurate in the mid speed range, like 30 - 40 mph.
it under states at lower speeds and over states at higher speeds versus the GPS. I often see wild claims of top speed for boats in Ad listings. . . I'm thinking they got those from the pressure speedo and not the GPS
Campylobacter
You are a far more charitable than I am, I assume they are lying. Or that all the 3.0's around here can do 50.
coolbri70
when i'm checking my top speed with gps i like to run upriver then down, i figure the diffirence is the rivers current speed and my top speed in the middle, so even if your speedo is correct, it will be off from your gps speed if the water is moving too
Capt Ken
I'm surprised the difference between running in hard water and soft water hasn't been discussed. We all know the boats run slower in hard water due to more hull resistance. Extensive studies in prop wash samples has proven this theory.
dan02gt
That's exactly how mine is. It's within 1MPH of my GPS between 30-50, but by the time I get to the high 50s it's as much as 5 off.
I like to say the that the GPS slowed a lot of boats down.
agallant80
Remember your GPS is going to show speed over ground, the meter in your boat will show speed over water, if there is a current it will add to your speed or take away depending on direction.
phonfish
Make sure you are not reading mph on one and knots on the other.
emilsr
Check your boat's speed on radar and you may find the GPS speed to actually be higher.
My first 2 boats didn't even have a speedo. Now I know why.
