Spider cracks in fiberglass.
joleda
What are some good recommendations to get rid of the spider cracks around screw holes and snaps?
Solittle
Re: Spider cracks in fiberglass.
Spider cracks are in the surface of the gel coat and are caused by the flexing or stress to the surface. As such they are cosmetic and have no effect on the structure. You could sand down and fill with new gel coat or paint if it is important to you. It is not worth the bother to me. I will wax the area though.
ondarvr
Like SL said, most of the time thay are just in the gel coat, they don't look good, but do no real harm. They can be difficult to repair and not have them come back because you need to eliminate the flexing or stress that caused them in the first place.
CodyGrizz
If you decide to fix them, depending on the size,there are a few steps. If they are small, like smaller than a nickel..you would be best off sanding the whole crack out. Now it will make a divit of course, but easy to fix. You can either use a gel coat repair kit or fiberglass repair (like kitty hair but finer) to fill in. I like to leave a little more in than I need in case of shrinkage so when it dries I can d/a sand it smooth, then poly primer or the primer of your choice, and paint.
For bigger ones..say over the size of a quarter I like to take a small sharp drill bit..usually on a high speed dremel of sorts..and gently drill a small shallow hole at the end of the crack, this will relive the cracks stress (not the reason for the crack though) s it wont crack on further. Then same thing..skim coat of gel repair over the area, d/a smooth, primer, paint.
Sometimes hose cracks happen around screws because its older gel coat and a screw was moved or the hole wasnt predrilled, sometimes it can be from boat flex and thats where a hole was so its easy to crack (think windshield..small pebble crack turns into the length of the windshield a month later from movement of car).
imported_Curmudgeon
Clean up the cracks as best you can, get some rubber gloves, mix up some Marine-Tex, use fingers to force the mixture into the cracks, let cure, wet sand smooth with 1000 grit or so. You'll be surprised how they disappear, and most won't reappear because the stress has already been relieved. :love:
flashback
all these are good suggestions. In addition to what Cody said, I like to use a small ball burr in a dremel and actually grind each crack out to enlarge it enough so the filler gets a good hold in the crack.. have fun...
