rickdb1boat
- Joined
- Jan 23, 2002
- 11,195
I have a new trailer that has the through the spindle lubrication zerk fitting. I know this is a good thing, as you can add grease and it will shoot through the spindle and get the back bearing too. Kinda like a repack without removing the bearings. My question is, I have always run Bearing Buddies on all my trailers and I want to know if I can put them on this one. My plan was to grease the bearings using the zerk fitting and then remove the fitting (To allow the pressure to go through the fitting), install the Bearing Buddy so it will keep positive pressure in the hub. Any advice or has anyone done this? Do I even need the Bearing Buddies with this set-up? Thanks........
