spit@shuter
starfire2426
Hey guys i'm having a probe. with a 90 hp yamaha. I recently got water in the gas tank so i completely defined and cleaned it all out. Then took of the carbs and clean them also put them back on and went to the water. Well not long after it started running through i readjusted the carbs ran like a kitten until the same thing happend did it all over again and again what am i doing wrong or what can i do? Marc
sigma
Re: spit@shuter
Did you blow out all the fuel lines, gas tank vent lines, change your water seperating filter, drain and clean engine fuel filter, change plugs?
BaileysBoat
Re: spit@shuter
Recheck for water. Got a water separating fuel filter on there?
Any idea how the water got in the fuel in the first place?
starfire2426
Re: spit@shuter
Yes i blew all that out, and i changed fuel and water seperater filter. Water got in through the vent on fuel cap. The motor is on a motauk if that tells you anything. Should i assume that there is still water some were. also how far should the pilot screw be turned out to see if i was right?
starfire2426
Re: spit@shuter
hey guys im still having overheating problems on the same 90 hp yamI have changed the thermostat and sense but when i exceed 25 mph it overheats what else can i do?
