Texas Prowler
Thread starter- Joined
- Aug 30, 2015
- 167
Ran the outboard in a big storage tub with a top. The lower unit has been removed to replace the water pump. The engine was ran for an hour at varying speeds. The engine seems to have a snappy throttle response, smoother idle and use a bit less gas then previously. Next up I'll order an impeller and put it all back together. After the outboard has seen some run time on the water I'll check the compression again.
