Splash guards enough?
BDbill
I bought a 1988 Alumacraft V-14 last year rated for a 25 HP. I took it up to Northern WI last year, and with a 25 HP outboard, 2 batteries, gas tank, and trolling motor in the back, it sits about 6-8 inches above the water line. It happened to rain maybe 1 inch in a downpour with waves blowing in on the dock it was tied to. Add in a boat water skiing around and around a 100 acre area not far from the dock, the back end of the boat had a fair amount of water splash in and probably 2 inches to spare, this happened in a 6 hour period.
Here is my question. That made me nervous, to the point where I'm wondering if I need to go with a lighter motor. I'd hate to do that since the 25 HP my father gave me has only 10-20 hours of use. Would splash guards and a bilge pump be enough? The boat only spends maybe 7-10 days a year in the water tied to a dock. Thanks for your input.
Capt'n Chris
Re: Splash guards enough?
Is your boat built for long or short shaft (16 or 21"). Is your motor 2 or 4 stroke? Splash guards? What do you have in mind?
Home Cookin'
You have too much stuff in the back of the boat. Put the trolling motor in the front, and its battery. Do you really need 2? a 25 is an easy pull-start. You might not need more than a 6 gallon tank, too.
At the dock, moor bow out to take the skier's waves. Take some weight out. And since you have a battery, definitely hook up a bilge pump w/ a float switch.
If the boat is rated for a 25, fine; it seems big for a 14' but I wouldn't get another motor. Be careful, as you are, about the freeboard and watch your conditions. Personally I think splash gaurds aren't addressing the real problem and may give a false sense of security. won't do much for a rain storm.
