[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
End of the season for me . . .
Trailer all set to go . .
The boat came on the bunks pretty much dead center.
(y)
Backing down my road/driveway was uneventful . . .
Lots of rain yesterday, so the boat had to take a pee.
Now for off-season maintenance. :unsure:
tpenfield
Just ordered my oil change stuff.
11 quarts of oil for each engine o_O + 2 quarts of gear oil.
@alldodge . . . my steering goes 4 turns lock-2-lock (30˚ pivot each way)
Pmt133
Everything seems to be 100 hours last I checked.
Typically the increased oil capacity is more to help with loading of the oil.... Most modern engines have larger sumps than I'm used to. My truck is 6 quarts. The GM LT V8s take about 9. Diesels are 5 gallons plus typically because of all the soot loading on the oil and allows for longer service life in the sump. I grew up with old crap so 5 quarts and a filter was normal.
alldodge
Verado is 7.4 quarts
Electric steering much better than hydraulic. Down side can you steer if pump doesn't run, found out by accident I can it's just hard
My Cummings 6.7 is 3 gallon of full syn and change every 15K
tpenfield
In addition to the engine servicing and height adjustment, I plan on doing some finish work on the Extension Bracket that I did not have time for this past Spring. . .
  • Epoxy coating on the internal areas,
  • Some additional fiberglassing around the corner trim pieces
  • Additional Fairing/smoothing/glossing of the exterior surfaces
  • Some non-skid on the top surface of the E-B.
A couple of nice things that I picked up in this transition . . .
  • Ignition Kill Lanyard (the original boat did not have one)
  • Garboard Plug (the original boat did not have a plug . . . PITA for winter layup)
Lou C
and you don't have to scrape the inevitable barnacles all over the transom bracket and outdrives lol. That all by itself saves a lot of time!
Oil qts, my old 1998 Jeep 4.0 takes about 6.5 qts and my 2007 Jeep 5.7 Hemi takes about 7.5 qts. Boat, only 4.5 for the 4.3.
